paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
JayboH
Apr 04, 2021Apprentice
Just updated it.
Works perfectly fine so far in Router mode from what I can tell.
Sure enough, some stuff is now missing, none of which I used anyway.
michaelkenward
Apr 04, 2021Guru - Experienced User
JayboH wrote:
Just updated it.
Thanks for taking the plunge and reporting back.
If it isn't too much trouble, if you use them, can you let us know if such features as Anywhere Access, ReadyCLOUD and ReadySHARE still work?
I've have never used Live Parental Controls, so that is non great loss. In any case Netgear and OpenDNS will part company at the end of the year. So even if a router's firmware still supports Live Parental Controls it won't work.
- JayboHApr 04, 2021Apprentice
I apologize, I do not use any of those features. I port forward one device, use BeamForming and MU-MIMO, and have everything else cranked with QoS intentionally turned off. That's about it really.
- michaelkenwardApr 04, 2021Guru - Experienced User
I donlt exp[evct nay problems, but the release notes
No problem. I was just being lazy.
It is easy enough to backtrack, so I'll try to give it a go myself and report back.
I don't expect any problems, but the release notes aren't as clear as they could be. (No surprise there then.)
Looks like all is well with ReadyCLOUD, ReadySHARE and Anywhere Access.
I can even get into the router's GUI with a browser on a mobile device on wifi.
I'm still trying to work out what they mean by "remote GUI access".
