paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
Wahaha
May 27, 2021Aspirant
Hello
I upgrade the firmware to Version 1.0.2.82 and I cannot login to the AP.
How can I login to my AP?
So far the AP work fine.
- michaelkenwardMay 28, 2021Guru - Experienced User
What does that mean?
You have a separate wireless access point of some sort?
You are using the R7800 in wireless access point mode?
Something else?
The R7800 has problems in AP mode with recent firmware. (I assume that you browsed through the earlier messages before hitching a ride on this conversation.)
Re: NETGEAR R7800 FIRMWARE v1.0.2.82 - NETGEAR Communities
Then there is the general issue of what you can do with a wireless access point.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- paillassouMay 28, 2021Apprentice
HELLO from FRANCE
=> " The R7800 has problems in AP mode with recent firmware. "
i can confirm since 10 months ... each fw update (1.0.2.7x... 1.0.2.82) big big pb in AP mode...
ARGHHHHHHHHH
i've remove that **bleep** of NETGEAR R7800 ... :smileymad:
it's a trash with the new firmware 1.0.2.82 :smileymad:
[ SOLUTION ] :
i've bought HUAWEI AX3 PRO WiFi 6+ Quad Core Enhanced Edition WS7200-30 = 50€ aliexpress... basta ...WORKS PERFECT !
bye- michaelkenwardMay 28, 2021Guru - Experienced User
Out of curiosity, why would someone buy an expensive router and then disable most of its features so that it works as an access point?
I should add that I also have a router in AP mode, attached to an R7800 as a router. In my case, the AO is an Orbi. So I get the benefits of the Orbi's wifi and the advantages of the R7800 router.
