paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip BE CAREFUL / Read this : https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0...
paillassou
May 28, 2021Apprentice
HELLO from FRANCE
=> " The R7800 has problems in AP mode with recent firmware. "
i can confirm since 10 months ... each fw update (1.0.2.7x... 1.0.2.82) big big pb in AP mode...
ARGHHHHHHHHH
i've remove that **bleep** of NETGEAR R7800 ... :smileymad:
it's a trash with the new firmware 1.0.2.82 :smileymad:
[ SOLUTION ] :
i've bought HUAWEI AX3 PRO WiFi 6+ Quad Core Enhanced Edition WS7200-30 = 50€ aliexpress... basta ...
WORKS PERFECT !
bye
michaelkenward
May 28, 2021Guru - Experienced User
Out of curiosity, why would someone buy an expensive router and then disable most of its features so that it works as an access point?
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
I should add that I also have a router in AP mode, attached to an R7800 as a router. In my case, the AO is an Orbi. So I get the benefits of the Orbi's wifi and the advantages of the R7800 router.
