MTinSC
Jan 31, 2024Aspirant
Netgear R7800
Can I use both 2.4GHz and 5.0GHz band on the same router?
microchip8
Jan 31, 2024Master
and it's Gigahertz, not Megahertz!
MTinSC
{sigh!} of course!
- MTinSCJan 31, 2024Aspirant
... any guidance about where I can find some guidance about doing that?
- plemansFeb 01, 2024Guru - Experienced User
You're info is brief. Are you trying to use both networks at the same time on the same device?
Trying to have the 2x networks running but with separate ssid's?
What are you actually trying to do?By default (pretty sure it's the default option) the R7800 uses smart connect which combines the 2.4ghz and 5ghz network into one network so they don't show up separately. They both still work but devices can bandsteer between the 2 networks.
