sdmiller50
Nov 12, 2022Follower
Netgear R7900 Can't Access Router
I am in a rural area and have a really flaky broadband company that needs me to disconnect the 5GHZ on my router to keep from interfering with their signal. I am trying to access the router so that ...
Nov 12, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update using a wired PC and web browser pointed at 192.168.1.1?
To make any advanced changes to the routers configuration, you have to log into the routers web page using a PC and web browser.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
