Yuri_81
Apr 28, 2023Aspirant
Netgear R8000 — Nighthawk X6 AC3200
Hi I was bought used Netgear R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router. But unfortunatelly WAN port didnt work (I call to provider and he said not saw link from my WANport , but he saw...
Apr 28, 2023Guru - Experienced User
What modem/gateway is it connected to?
Did you try testing it on itself?
Yuri_81
Yes.I was try....As I said WAN port died...But LAN ports alive all. How I can do WAN port from LAN port?
- michaelkenwardApr 28, 2023Guru - Experienced User
Yuri_81 wrote:
Yes.I was try....
What was the result?
Maybe that bit of your second hand router is dead. Perhaps that is why the original owner sold it.
Netgear's routers rarely, if ever, allow users to turn a LAN port into a WAN port.
Your first message said:
(I call to provider and he said not saw link from my WANport , but he saw link from my LAN ports when i insert the cable in any LAN ports).
What do they mean by "he saw link from my LAN ports when i insert the cable in any LAN ports"?
Just because the LAN ports work does not mean that there is a connection between the WAN port and the router. If your R8000 is bust, it is bust.
I hope you didn't pay much for it. Netgear released this device in 2016.
- Yuri_81Apr 30, 2023Aspirant
As I said is issue with WAN port. Is 4 working LAN ports (the same type rj45).
I asked How can I remap the ports programmatically.( This for example was possible on the old TP link)
- FURRYe38Apr 30, 2023Guru - Experienced User
Check under router ip address/debug.htm to see if there is a Mirror WAN to LAN option there...
