Yuri_81
Apr 28, 2023Aspirant
Netgear R8000 — Nighthawk X6 AC3200
Hi I was bought used Netgear R8000 — Nighthawk X6 AC3200 Tri Band WiFi Gigabit Router. But unfortunatelly WAN port didnt work (I call to provider and he said not saw link from my WANport , but he saw...
Yuri_81
Apr 30, 2023Aspirant
As I said is issue with WAN port. Is 4 working LAN ports (the same type rj45).
I asked How can I remap the ports programmatically.( This for example was possible on the old TP link)
michaelkenward
Apr 30, 2023Guru - Experienced User
No you didn't. You said nothing about "programmatically".
You asked, several times, "How I can do WAN port from LAN port?"
Only some Netgear routers have that sort of feature built in.
As FURRYe38 suggested, go to:
Look for something like
WAN Port mirror to LAN port 1
This is what I get on the R7800.
