jhclinch
May 24, 2021Aspirant
Netgear R8000 - Internet works on wired connections but not on wifi
Hi, I've tried working with Netgear support to no avail, so I'm hoping someone can help me out here. For some reason, the internet is working on my wired connections, but not on my wifi. My ...
- May 25, 2021
Try installing version 1.0.4.28 of the firmware. Then do a factory reset and disable auto-updates.
try that version of the firmware. the newer versions got netgear armor and not all played nicely with armor.
Nighthawk X6 R8000 | AC3200 Tri Band Router | NETGEAR Support
May 24, 2021Guru - Experienced User
what modem/gateway is the router connected to?
Waht firmware is on the router?
what "tweaks" did support have you do?
how old is the router?
jhclinch
Modem: Netgear CM1000v2
Firmware: V1.0.4.68_10.1.75
They had me change 5G and 2.4G to the highest channel, but I've since done a factory reset to default settings.
I just bought the router and modem ~3 months ago.
Thanks
- plemansMay 25, 2021Guru - Experienced User
