ChristianWis
Mar 30, 2016Aspirant
Netgear R8000 - USB Storage and Samsung led tv
Hello everyone I have a router with a USB R8000 1TB disk and a LED TV Samsung F5500 model with the latest update. When I want to watch movies on the disc appear sometimes shared folders and other ti...
- Apr 17, 2016
Hi ChristianWis,
Are you still having issues with your router. Please provide an update.
JamesGL
Apr 04, 2016NETGEAR Employee Retired
Hi ChristianWis,
1. Can you access the files or movies when using a computer?
2. What is the file format of your drive?
3. Can you try to use a different USB drive and see if the same problem?
4. What is the firmware version of the router?
ChristianWis
Apr 09, 2016Aspirant
Hi
Sorry by delay..
Hi ChristianWis,
Yes, I can to access using a computer
Format is NTFS
I cant, i have not another usb drive
the firmware is V1.0.3.4_1.1.2
Thanks in advance
Christian
