ChristianWis
Mar 30, 2016Aspirant
Netgear R8000 - USB Storage and Samsung led tv
Hello everyone I have a router with a USB R8000 1TB disk and a LED TV Samsung F5500 model with the latest update. When I want to watch movies on the disc appear sometimes shared folders and other ti...
- Apr 17, 2016
Hi ChristianWis,
Are you still having issues with your router. Please provide an update.
ChristianWis
Apr 09, 2016Aspirant
Hi
Sorry by delay..
Hi ChristianWis,
1. Can you access the files or movies when using a computer?
Yes, I can to access using a computer
2. What is the file format of your drive?
Format is NTFS
3. Can you try to use a different USB drive and see if the same problem?
I cant, i have not another usb drive
4. What is the firmware version of the router?
the firmware is V1.0.3.4_1.1.2
Thanks in advance
Christian
JamesGL
Apr 17, 2016NETGEAR Employee Retired
Hi ChristianWis,
