cbc7's avatar
cbc7
Follower
May 16, 2021
NetGear R8000 openvpn warnings can't solve
Hi,
I can connect to Negear R8000 with Openvpn 2.5.2 but receive 2 warnings that I can't seem to shake. Tried adding and removing different lines/commands to the config.ovpn file with no success. Can't seem to find a solution. I have latest router firmware, but maybe Netgear needs to release new firmware?
Any thoughts?
1.)WARNING: No server certificate verification method has been enabled. See "http://openvpn.net/howto.html#mitm" for more info.
2.) ROUTE: route addition failed using service: The parameter is incorrect. [status=87 if_index=36]
client
dev tap
proto tcp
dev-node NETGEAR-VPN
remote ip.address 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
mssfix 1430
auth-nocache
route-gateway 192.168.1.1
No RepliesBe the first to reply
