kshangaun's avatar
kshangaun
Follower
Apr 17, 2023
NETGEAR R8000 router capped at 100mbps
So I recently got ATT Fiber and I plugged MY router into one of my houses ethernet port. The reason why I can't connect my router straight to the modem is because my modem is in a tight closet. I noticed while I was on my router network, the speeds were under 100mbps. I looked into ATT's login page and found my router information and says "connection speed: 100mbps fullduplex. Ive edited the ports so that its 1G full duplex but when I go back to the description it says 100mbps. I tried many solutions like checking all the cables, resetting the router. The confusing thing is that I was getting 1G internet on spectrum cable. PLZ HELP!!!
  • michaelkenward's avatar
    michaelkenward
    What is that modem? Make and model?
    What sort of Internet service do you have now?
  • plemans's avatar
    Have you tried moving the router to right next to that att gateway and connecting it with a known good 6ft cable?
    If you have it in a closet, you have a fairly long run and probably custom ends on that cable. I've frequently seen poor ends or cables cause it to drop from gigabit to 10/100mbps.
