chevyavalanche
Jul 12, 2022Aspirant
Netgear R8000 Router setting, then setting to AP mode, then set back to Router mode
So I have my R8000 set to 10.0.x.x instead of the out of the box 192.168.x.x setting. I'm thinking of setting it to AP mode to use another 'router' that doesn't have WiFi built in. If I want to set r...
Jul 12, 2022Guru - Experienced User
It will revert back to last configuration that you set on the router.
- chevyavalancheJul 18, 2022Aspirant
Thanks for the reply! I was hoping it would do that.
