MILINDN's avatar
MILINDN
Tutor
Aug 30, 2021
Netgear R8000 to Netgear unmanaged switch GS316 stopped working after firmware upgrade.
I have a xfinity modem -> nighthawk r8000 router -> Netgear unmanaged switch (GS316) which combo was working fine until last week! Now after the firmware upgrade all WiFi works fine. but the ethernet...
  • plemans's avatar
    Aug 31, 2021
    You can try saving a backup configuration and reinstalling that after the reset.
    But try the switch after the reset and default configuration. If it works but not after you resetore, then you know you need manually reinstall it and not use the backup.
