OldDutch's avatar
OldDutch
Follower
Jun 17, 2022
Netgear R8000 will not connect "page blocked"
Have Netgear Nighthawk X6 R8000 that I am having problems with.
After a service interruption, provider outage, my router will no longer allow me to connect to the internet.
My service provider disabled the wifi from the modem and bridged it directly to my router.
Every device says I am connectedto the router, but the connection has no internet and tells me to login to the router. When I do it tells me that the "Page is blocked by x6 R8000."
This occurs online and via the Nighthawk app.
Have tried everything with service provider technical support and have done multiple resets.
Nothing is happening.
Any advice.
1 Reply
  • FURRYe38's avatar
    Do you have Smart Parental controls or Armor enabled by chance on the router?
