raphaelcampelo
Sep 21, 2021Guide
Netgear R9000 - poor performance wired and wi-fi
Hi there, hope everybody is doing fine ... I bought a NetGear R9000 AD7200 router 6 months ago, and until 10 days ago, everything was awesome. Suddenly, I noticed that I'm not getting more than 9...
- Sep 23, 2021
Hi guys ... thanks a lot for the attetion. Today a received a technical guy from my carrier, and after some tests, he changed cable connector ... yes, just changed the connector, and everything is perfect again.
I couldn't believe, but that's the fact. The issue was phisical.
Thanks a lot for all the support and feedback here
Sep 22, 2021Guru - Experienced User
Possibly something on the ISP side could have changed as well...
raphaelcampelo
Sep 23, 2021Guide
- plemansSep 23, 2021Guru - Experienced User
Glad it fixed the issue!
- FURRYe38Sep 23, 2021Guru - Experienced User
Glad that was all.
Enjoy.
