wincy74's avatar
wincy74
NETGEAR R9000 NIGHTHAWK X10 BLOCKS CERTAIN WEBSITES
Good evening everyone, I am having an issue that I hope you can help me with. My Netgear R9000 Nighthawk has been blocking a few secured websites. For example, I cannot access www.kbb.com via my inte...
  • wincy74's avatar
    wincy74
    Jan 28, 2020
    michaelkenward wrote:
    You have tried this with different browsers?
    wincy74 wrote:
    For example, I cannot access www.kbb.com via my internet ....
    What happens when you try. Surely you get some sort of message? That might help someone to diagnose what is going on.
    Thanks your response. I can't remember the exact verbiage, but it was something about the website is taking too long to respond. The router is working properly now. I'm not sure if I fixed it or it fixed itself. Last night after the my post here, I reset it to factory settings a few times and powercycled it after each reset.
