HelpmeIdk
Jul 05, 2020Aspirant
Netgear R9000 nighthawk x10 internet appears offline when there’s connection
I just recently got the router. Heard it was one of the best. When I downloaded the nighthawk app, next to the image it says “internet: offline.” I tried restarting the router and the modem. Checked i...
- Jul 10, 2020I accidentally figured it out. I thought AP mode is the best, which wasn’t in my case, so I swapped back to router mode. I just went on https://www.routerlogin.com to do all of that but you have to connect an ethernet cable to from your router and to a computer. Then as I swapped back from AP mode it now accurately shows the status as online from now on.
HelpmeIdk
Jul 10, 2020Aspirant
antinode
Jul 10, 2020Guru
> Is this just a classic NETGEAR firmware bug?
Wouldn't amaze me.
> I accidentally figured it out. I thought AP mode is the best, [...]
You might have been right.
> which wasn't in my case, [...]
And you might now be wrong.
> [...] so I swapped back to router mode. [...]
That may correct the problem with the Internet indicator, but it may
still be a bad idea. Cascading multiple routers can cause multiple
problems. These include "double NAT", and complications in
communication between local devices which are on different IP subnets.
> [...] I just went on https://www.routerlogin.com to do all of that but
> computer. [...]
A wireless connection to the R9000-as-WAP should work as well. Or,
get the (new) LAN IP address of the R9000-as-WAP from the main router
(an "Attached Devices" or "DHCP Clients" or similar report) and use that
address.
If your "ARRIS BGW210-700 modem" is really acting as a modem+router,
not as a simple "modem", then you might have less trouble with the R9000
configured as a WAP, faulty Internet indicator or not.
