socalspartan
Nov 11, 2016Aspirant
Netgear r9000 PLEX media server problem
Hi, so I'm trying to enable the plex media server on my r9000 and I cant seem to get it to work. I checked the enabled plex. It says USB drive connected, but I see a "Check your internet" in grey a...
- Nov 13, 2016
If you can I would have it replaced. My R9000 has been rock solid but yours sounds like a Friday afternoon build!
clithes
Nov 11, 2016Prodigy
Not seen that error before, but its making reference to NTP server
Can you log into the router GUI and go to Advanced --> Administration --> NTP Settings
What does it look like? Are there any errors? Does it show date and time under 'Current Time: ' ?
I currently have mine set like this and Plex Server is running ok
Also, what firmware are you running?
ElaineM
Nov 11, 2016NETGEAR Employee Retired
socalspartan I suggest that you contact support for further diagnosis.
