socalspartan
Nov 11, 2016Aspirant
Netgear r9000 PLEX media server problem
Hi, so I'm trying to enable the plex media server on my r9000 and I cant seem to get it to work. I checked the enabled plex. It says USB drive connected, but I see a "Check your internet" in grey a...
- Nov 13, 2016
If you can I would have it replaced. My R9000 has been rock solid but yours sounds like a Friday afternoon build!
clithes
Nov 11, 2016Prodigy
Not seen that error before, but its making reference to NTP server
Can you log into the router GUI and go to Advanced --> Administration --> NTP Settings
What does it look like? Are there any errors? Does it show date and time under 'Current Time: ' ?
I currently have mine set like this and Plex Server is running ok
Also, what firmware are you running?
socalspartan
Under NTP settings, its showing Jan. 1, 1970 11:22:22
Using default NETGEAR NTP server. How do I change the date to current?
- clithesNov 11, 2016Prodigy
Ok so it isnt picking the correct date and time up
Change the NTP server as per my screenshot (take it off the default netgear server and type in the new server) to see if this makes a difference.
Also can you confirm which firmware you are using, it may be that this just needs updating
- socalspartanNov 12, 2016Aspirant
The firmware version is. V1.0.1.20
I changed the NTP to uk.pool.ntp.org
Still greyed out, and still showing old date. Is it defective? I can still return and exchange for a new one.
