socalspartan
Nov 11, 2016Aspirant
Netgear r9000 PLEX media server problem
Hi, so I'm trying to enable the plex media server on my r9000 and I cant seem to get it to work. I checked the enabled plex. It says USB drive connected, but I see a "Check your internet" in grey a...
- Nov 13, 2016
If you can I would have it replaced. My R9000 has been rock solid but yours sounds like a Friday afternoon build!
socalspartan
Nov 12, 2016Aspirant
Its PACE 5268AC. Its a uverse gateway modem/router combo.
clithes
Nov 13, 2016Prodigy
I wonder whether something is wrong behind the timezones code
If you go to Advanced --> Security --> Schedule
and change your timezone to something different, and hit 'Apply', does it then show a correct date and time (for that zone)?
Just in case the firmware is corrupt, it may be worth downloading it and applying it again yourself?
https://www.netgear.com/support/product/R9000.aspx#download
Let us know if this fixes anything?
- socalspartanNov 13, 2016Aspirant
I changed to different time zones and still showing Dec 31, 1969 to Jan 1, 1970 depending on the time zone. I redownloaded and installed the v.1.0.1.20 firmware and still same. Should I just return it? I just bought this a week ago, too much headache already.
- clithesNov 13, 2016Prodigy
- socalspartanNov 14, 2016Aspirant
I went to bestbuy and replaced my r9000. It works now, correct date and plex works. I wonder why the other one has the old date and wont update.
