socalspartan
Nov 11, 2016Aspirant
Netgear r9000 PLEX media server problem
Hi, so I'm trying to enable the plex media server on my r9000 and I cant seem to get it to work. I checked the enabled plex. It says USB drive connected, but I see a "Check your internet" in grey a...
- Nov 13, 2016
If you can I would have it replaced. My R9000 has been rock solid but yours sounds like a Friday afternoon build!
socalspartan
Nov 13, 2016Aspirant
I changed to different time zones and still showing Dec 31, 1969 to Jan 1, 1970 depending on the time zone. I redownloaded and installed the v.1.0.1.20 firmware and still same. Should I just return it? I just bought this a week ago, too much headache already.
clithes
Nov 13, 2016Prodigy
- socalspartanNov 14, 2016Aspirant
I went to bestbuy and replaced my r9000. It works now, correct date and plex works. I wonder why the other one has the old date and wont update.
- ElaineMNov 15, 2016NETGEAR Employee Retired
Some ISPs may block the default NTP server used by R9000 and as result features such as PLEX will not work until the R9000 is able to obtain the correct date and time from the NTP server. If you encounter this issue please log into your R9000 and go to Advanced NTP Settings and choose the Set your Preferred NTP server and enter one of the public NTP servers in the Primary NTP server field and click Apply. If the NTP server is not blocked by your ISP the current time field should be updated to the correct date/time.
For list of NTP server please refer to one of the following links:
- For the list of Stratum One time servers, go to the following website:
http://support.ntp.org/bin/view/Servers/StratumOneTimeServers
- For the list of Stratum Two time servers, go to the following website:
http://support.ntp.org/bin/view/Servers/StratumTwoTimeServers
- For the list of NTP pool servers, go to either of the following websites:
- gjadNov 18, 2016Initiate
Go to internet setup then check use this mac put the mac address of the router ...that will fix date and time!!!
