njebudalla
Nov 11, 2021Aspirant
Netgear r9000 will not retain configuration
I have an R9000 that will not retain configuration if powered off. For example, if the electricity cuts, when I am unable to connect to the wifi, and I try to log into the gui, it's completely reset...
Nov 12, 2021Guru - Experienced User
what firmware version are you on?
njebudalla
Dec 07, 2021Aspirant
Thanks for your reply.
Router Firmware Version
V1.0.3.6
I have tried to change version without success. It still manifests the same problem of not retaining configuration.
- FURRYe38Dec 07, 2021Guru - Experienced User
How are you updating FW?
Your using older FW. Maybe new FW will fix this...
