hspindel2's avatar
Sep 25, 2023
Netgear R9000 won't reset
I purchased a used Netgear R9000.  It powers up fine.   Unfortunately, it powers up at IP 192.1.1.5.1 instead of the factory default.  Going to the web page at 192.1.1.5.1 does give me the logon bo...
  • FURRYe38's avatar
    Sep 25, 2023
    Try nmrpflash instead of TFTP.
    If the 30-30-30 reset doesn't work then router maybe busted.
