hspindel2
Sep 25, 2023Guide
Netgear R9000 won't reset
I purchased a used Netgear R9000. It powers up fine. Unfortunately, it powers up at IP 192.1.1.5.1 instead of the factory default. Going to the web page at 192.1.1.5.1 does give me the logon bo...
- Sep 25, 2023
Try nmrpflash instead of TFTP.
If the 30-30-30 reset doesn't work then router maybe busted.
hspindel2
Sep 28, 2023Guide
It took many tries and much fooling with nmrpflash, but it eventually worked. Thank you so much for the pointer!
Sep 29, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
