Eckhartfamily5
Sep 05, 2017Aspirant
Netgear R9000
I have the router setup with an Arris modem/Xfinity. The main computer is a Mac with is connected by ethernet. I have devices connected to 2 of the bands. My computer, phones, ipad are connected to th...
- Sep 10, 2017
I ended up calling support. Apparently there was a wrong IP address in the wrong place that was causing issues. I ended up doing a hard reset and using Genie to set up again. Seems much better for now.
ElaineM
Sep 07, 2017NETGEAR Employee Retired
Welcome to the community, @Eckhardfamily5
Did you try to other ports on the router?
How about changing the cable?
Can you check if you'll experience the same problem if you use a different device connected through wired?
It might be the LAN card on your Mac computer.
- Eckhartfamily5Sep 10, 2017Aspirant
- ElaineMSep 11, 2017NETGEAR Employee Retired
Great to hear. Thank you for the update!
