Johndeb's avatar
Johndeb
Follower
Aug 26, 2021
Netgear RAX20
Is it necessary to download netgear Armor to each device, or does the netgear router provide protection to your system?
1 Reply
  • plemans's avatar
    Depends on what your doing.
    Armor on the the router is basically a nice gateway. But if you're needing more comprehensive, then install it to your device.
