Dmrts
Feb 02, 2022Aspirant
Netgear Rax80 - Circle On Netgear
I have a RAX80 router and about a week ago I have purchased Circle on Netgear App from Iphone for about $73. I try to contact help with Cirlce direct they told me I shall get help from Netgear. Wh...
michaelkenward
Feb 02, 2022Guru - Experienced User
Two points, first you might get more help in the Circle zone:
Circle Smart Parental Controls - NETGEAR Communities
Secondly, the RAX is also best talked about in its hardware area.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Dmrts
Thank you very much for your help.
I m trying to find answer in those links you gave.
