JAM83
Sep 30, 2023Aspirant
Netgear ReadyShare
So I enabled ReadyShare and added a 6TB External HDD so I can set up Plex server. How do I go about hiding the "System Volume Information" Folder or even delete it. I'd rather just hide it since it will recreate itself
I have the NETGEAR Nighthawk R7350 AC2400 Router (It wouldn't let me add it to "Associated Products)
JAM83 wrote:
So I enabled ReadyShare and added a 6TB External HDD so I can set up Plex server. How do I go about hiding the "System Volume Information" Folder or even delete it. I'd rather just hide it since it will recreate itselfThat's down to the operating system that connects to the USB drive on ReadySHARE,
Why do you want to hide the folder?
I have the NETGEAR Nighthawk R7350 AC2400 Router (It wouldn't let me add it to "Associated Products)Might help if you looked in the appropriate section for your router:
Nighthawk Wi-Fi 5 (AC) Routers - NETGEAR Communities
- JAM83AspirantI just don't want to see any unnecessary folders. It's annoying. I wish I could just delete it, but it'll just come back so I'd rather hide it.
- JAM83Aspirant
I posted it in the correct forum. I literally couldn't find it. So, this one can be closed/deleted.
This is unnecessary.
The answer doesn't change.
Check how to use your operating system.
- JAM83Aspirant
So I enabled ReadyShare and added a 6TB External HDD so I can set up Plex server. How do I go about hiding the "System Volume Information" Folder or even delete it. I'd rather just hide it since it will recreate itself.
(Nighthawk R7350 AC2400)
