Vitalie
Dec 24, 2022Aspirant
Netgear router AC 1750, model R6700
Hello, have a nice day, Please help me. I buy from Amazon Netgear router AC 1750, model R6700. When I opened the box, I found that the AC adapter is for USA with voltage 100-120V. But I inten...
michaelkenward
Dec 24, 2022Guru - Experienced User
Vitalie wrote:
I have some questions
1) Can I use this router with another plug adapter of another manufacturer, with voltage 220-240V, output 12V -2,5A ?
Yes. Generic adapters are fine. Netgear doesn't supply them really, so that is always the advice here.
You may already have something suitable lying around.
Any generic adapter will work, as long as it has the right volts, enough amps, the right (+/-) polarity and a tip that fits the router. Some adapters come with a set of different interchangeable tips.
Generic adapter
2) Or if I connect a 220 -240V plug adapter to this router, can this router explode, or short circuit?
Not sure that I understand that. If you want to plug your existing 120 Volt adapter into a 240 Volt socket, the only thing that will go bang is the adapter, especially if it isn't plug into the router.
But my experience has been that adapters marked for 100-120V work just fine at 240 V. I have done this safely with several Netgear adapters. No damage done.
My theory is that Netgear supplies dual voltage adapters but there are hassles, and maybe legal issues, with labelling them as dual voltage.
- VitalieDec 24, 2022Aspirant
My question would be if I could connect to a Netgear router with 110 -120V charger, a 220-240V charger, to use the router in Europe?
Won't the router explode already because I plugged in a 220-240V adapter?
Thanks for any suggestions- michaelkenwardDec 24, 2022Guru - Experienced User
No. The adapter might explode. It sits between the main and the router. And if it is going to blow up, it will do that even if you don't connect it to the router. Just plug it in and turn it on. If it goes bang, then the router is unharmed and you need to find a new adapter.
But my experience s that Netgear's 110V adapters are fine at 240V.
Do you have the part number on your adapter? I have a couple that work on 240V.
- plemansDec 25, 2022Guru - Experienced User
I would return it. The NA region ones are region locked. You won't be able to change its region to be compatible with your region and it can cause issues with connections (much less your broadcast regulatory issues)
- michaelkenwardDec 25, 2022Guru - Experienced User
I think that is a reference to the wifi region. Nothing to do with the mains adaptor.
It isn't quite true that you can't change the wifi region.
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities
But it isn't easy and is a hassle best avoided where possible. Netgear may even have blocked that option by now.
But we don't know where you bought this router. (Amazon has been known to ship the wrong stuff, especially from third party sellers.) You might want to check if it really is locked.
