2Charlie
Jun 17, 2016Aspirant
NETGEAR router is not found or is not supported.
I get this error: NETGEAR router is not found or is not supported. Also make sure the device is not connected to the guest network of the ourter, and no IPv6 is enalbed. I'm simply trying to ...
- Jun 17, 2016
Ok, I looked at the Genie manual and there's a whole section on remote managment. It turns out that Remote Management does NOT need to be enabled on the router. Remote management with Genie uses a different mechanism. You need to create a remote management account and register your router. Follow the instructions in the manual to set it up. They look easy to follow.
Having said this, I would be a bit wary about using this. The use of a remote managment account implies that remote access is faciliated by a Netgear server. After the initial setup, it's unclear how much Netgear is involved whenever you log in remotely. Hopefully, your login session doesn't go through any Netgear servers. That would be a huge privacy concern. What would be preferred is that the act of registering your router for remote management merely opens a port on the router and Genie opens a direct connection to router. Unfortunately, you have to log into the remote management account in order to access your router, so that suggests that Netgear is still involved.
Unless Netgear is willing to share more details about how this works, I would stay away from this feature and stick with the basic, browser-based Remote Management available on the router.
My $0.02, of course.
TheEther
Jun 17, 2016Guru
2Charlie
Thank you so much for the information. That is very helpful and insightful.
