HavingBigProbs
Dec 03, 2016Aspirant
NETGEAR router is not found or is not supported.
Hello guys, I'm having a hard time right now. I bought the NightHawk AC1900 R7000 to install a VPN on it. I installed the VPN showed in this video '' https://www.youtube.com/watch?v=FVLQzsCxwgI '' an...
- Dec 06, 2016
That 192.168.0.20 looks wrong.
There are often problems coming back from dd-wrt to stock firmware and it's often difficult to find what you need to do on the dd-wrt forums.
The problem might be dd-wrt leaving conflicting NVRAM settings, you should have set the router back to factory defaults in dd-wrt before loading the firmware.
Even so the NVRAM settings can still conflict requiring they be erased before things will work properly.
I don't know if the Netgear tftp firmware update procedure will also erase NVRAM when the firmware is uploaded, a Netgear person will need to answer that one.
But if it does that could be a way to resolve the problem too.
You could try making sure no other devices are using DHCP assigned addresses by, perhaps, turning them off (so that there won't be a possible duplicate address).
But then the router appears to have an incorrect DHCP address range set so this might not be a problem at all, better to be safe though.
Then set your computer's address manually to one that is in the range 192.168.1.2-254, probably over 200 is better in case there ends up being a duplicate address on the network, as the higher addresses are less likely to be assigned by the DHCP server in the router.
For the subnet mask use 255.255.255.0 , as usual, and the gateway 192.168.1.1, and DNS 192.168.1.1, as it is in the above post.
If the router has an address of 192.168.1.1 (and it appears it does from the above post) then your computer with address 192.168.0.(anything) will not be able to communicate with the router or anything else in the 192.168.1 network. That's the point of setting the address manually.
Then try to connect to 192.168.1.1 in a browser and see if it works.
HavingBigProbs
When I enter 192.168.1.1 it always says it loading timed out and I tried doing it with the Ethernet cable, or even trying to connect to the default Netgear Wifi network but it always times out.
I don't know what is Kaspersky I'm pretty sure I dont have it but ill keep looking for it.
- HavingBigProbsDec 04, 2016Aspirant
I don't have KasperSky. If anybody would have any tip to help me it would be appreciated! Thanks TheEther for trying.
- ElaineMDec 06, 2016NETGEAR Employee Retired
Do you have any firewall at all?
If you do, try to turn it off.
Can you still communicate with the router by pinging that IP address in the command prompt?
See the link below.
- HavingBigProbsDec 06, 2016Aspirant
ElaineM : i still can communate with my router
It's in french, if you need other info just tell me
IrvSp :Carte Ethernet Connexion au réseau local :
Suffixe DNS propre à la connexion. . . :
Description. . . . . . . . . . . . . . : Realtek PCIe FE Family Controller
Adresse physique . . . . . . . . . . . : 00-1E-33-C9-45-A6
DHCP activé. . . . . . . . . . . . . . : Oui
Configuration automatique activée. . . : Oui
Adresse IPv6 de liaison locale. . : fe80::ad7f:d59a:a48c:c5bc%10(préféré)
Adresse IPv4. . . . . . . . . . . : 192.168.0.20(préféré)
Masque de sous-réseau. . . . . . . . . : 255.255.255.0
Bail obtenu. . . . . . . . . . . . . . : 6 décembre 2016 19:55:14
Bail expirant. . . . . . . . . . . . . : 7 décembre 2016 19:55:13
Passerelle par défaut. . . . . . . . . : 192.168.1.1
Serveur DHCP . . . . . . . . . . . . . : 192.168.1.1
IAID DHCPv6 . . . . . . . . . . . : 167779891
DUID de client DHCPv6. . . . . . . . : 00-01-00-01-18-16-92-AC-00-1E-33-C9-45
-A6
Serveurs DNS. . . . . . . . . . . . . : 192.168.1.1
NetBIOS sur Tcpip. . . . . . . . . . . : ActivéCarte Tunnel Connexion au réseau local* 6 :
Statut du média. . . . . . . . . . . . : Média déconnecté
Description. . . . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Adresse physique . . . . . . . . . . . : 02-00-54-55-4E-01
DHCP activé. . . . . . . . . . . . . . : Non
Is the first one a bit too different?
- IrvSpDec 06, 2016Master
For one thing to try, clear the Cache on the Browser. Another would be try a different browser.
Also, from the CMD prompt enter IPCONFIG /ALL and copy and paste the results into a reply. Should look like this:
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : F8-B1-56-DD-6A-CC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::58bf:9e27:bf45:87e8%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.30(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, December 6, 2016 4:20:43 PM
Lease Expires . . . . . . . . . . : Wednesday, December 7, 2016 4:20:43 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 49852759
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-04-98-17-F8-B1-56-DD-6A-CC
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : EnabledRED lines should be similar but the first one should have a different last Octet.
