HavingBigProbs
Dec 03, 2016Aspirant
NETGEAR router is not found or is not supported.
Hello guys, I'm having a hard time right now. I bought the NightHawk AC1900 R7000 to install a VPN on it. I installed the VPN showed in this video '' https://www.youtube.com/watch?v=FVLQzsCxwgI '' an...
- Dec 06, 2016
That 192.168.0.20 looks wrong.
There are often problems coming back from dd-wrt to stock firmware and it's often difficult to find what you need to do on the dd-wrt forums.
The problem might be dd-wrt leaving conflicting NVRAM settings, you should have set the router back to factory defaults in dd-wrt before loading the firmware.
Even so the NVRAM settings can still conflict requiring they be erased before things will work properly.
I don't know if the Netgear tftp firmware update procedure will also erase NVRAM when the firmware is uploaded, a Netgear person will need to answer that one.
But if it does that could be a way to resolve the problem too.
You could try making sure no other devices are using DHCP assigned addresses by, perhaps, turning them off (so that there won't be a possible duplicate address).
But then the router appears to have an incorrect DHCP address range set so this might not be a problem at all, better to be safe though.
Then set your computer's address manually to one that is in the range 192.168.1.2-254, probably over 200 is better in case there ends up being a duplicate address on the network, as the higher addresses are less likely to be assigned by the DHCP server in the router.
For the subnet mask use 255.255.255.0 , as usual, and the gateway 192.168.1.1, and DNS 192.168.1.1, as it is in the above post.
If the router has an address of 192.168.1.1 (and it appears it does from the above post) then your computer with address 192.168.0.(anything) will not be able to communicate with the router or anything else in the 192.168.1 network. That's the point of setting the address manually.
Then try to connect to 192.168.1.1 in a browser and see if it works.
HavingBigProbs
Dec 06, 2016Aspirant
I tried reaching the website with a different browser and cleared the cache it stills Times out
raven_au
Dec 06, 2016Virtuoso
- IrvSpDec 07, 2016Master
I've gone from NG --> DD-WRT and DD-WRT --> NG a few times without problems. I've not seen this problem doing so, so I don't think that might be the problem. I'd suspect with the Router was set to 192.168.0.1 before manually or because of other devices causing it to use that IP Address or DD-WRT was set to that. Also possible the Network Adapter didn't sense a new IP Address for the router and never changed. That 192.168.0.20 is fairly high too so I suspect it was set manually. I set mine to 192.168.1.30 specifically so I'd know its IP Address if I needed to access it via IP Address (another PC is set to 192.168.1.40) and I set the first 19 addresses to be the limit to be handed out. Maybe the OP did something similar?
