S2zq
Jun 04, 2021Follower
Netgear Router Nighthawk AC1900 R7000 keeps dropping connection to Netgear Modem
Bought this router approximately 1 year ago also purchased a Netgear modem (CM1000) using Spectrum Internet service. Spectrum is working fine but the router keeps dropping connection to various device...
Jun 04, 2021Guru - Experienced User
Try using the 1.0.11.123 firmware. Install it manually, then do a factory reset and new install.
https://www.netgear.com/support/product/r7000.aspx
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
