thechonch
May 09, 2020Tutor
Netgear Router Nighthawk not supported with Spectrum Internet
Listed here are all the Spectrum approved routers. https://www.spectrum.net/support/internet/modems-routers-wireless-adapters/ I recently bought a Netgear Nighthawk router from amazon (AC1900 -...
- May 30, 2020
Finally had some free time to work with tech support. Turned out the original person who tried activiating router was not the sharpest tool in the shed.
New tech guy got me done in 10 mins. Thanks for the help all.
May 09, 2020Guru - Experienced User
What modem or router did you buy?
Model numbers help.
You listed the A7000 which is a wireless usb adapter.
- thechonchMay 09, 2020Tutor
Thank you, edited original Post with model.
- plemansMay 10, 2020Guru - Experienced User
The C7000 works with spectrum.
And its on the qualified up to 400mbps list.
And my in laws are running this same modem on spectrum with 200 mbps service.
It potentially could be a line issue or just having a bad technician provisioning it.
