dokastho
Jan 23, 2022Follower
Netgear Router Orbi disconnects devices with static ip
Hello, I have a router orbi running the latest firmwar (not sure about model) that keeps disconnecting my devices with a static ip I set the IP using advanced > lan setup > <filled out info and hit...
Jan 23, 2022Guru - Experienced User
what modem is it?
When the device disconnects, what error do you get? does it say "connected, no internet". Does it see the wifi but not connect to it? does it not see the wifi at all? What actually happens?
Does it happen to wired devices ?
