gpnj
Mar 26, 2022Aspirant
Netgear Router rejecting connections from Roborock vaccume and Govee water leak system
After updating firmware on router Netgear R6900v2, it is rejecting Roborock vaccume and Govee devices on my network. Both their data centers are in China I guess. This has happened only after upgrad...
Apr 07, 2022Guru - Experienced User
What security mode are you using on the router? WPA2?
Try WPA and TPIK to see if they connect?
gpnj wrote:
After updating firmware on router Netgear R6900v2, it is rejecting Roborock vaccume and Govee devices on my network. Both their data centers are in China I guess. This has happened only after upgrading to firmware version V1.2.0.90_1.0.1. Earlier bother were able to connect to wifi without any issue. I have checked access controls and everything looks good. Below error is thrown continusly for both the devices mac addresses.
[WLAN access rejected: incorrect security] from MAC address b2:b9:8a:4e:d7:6d Saturday, March 26,2022 13:47:55
- gpnjApr 07, 2022Aspirant
Just tried your suggestion, changing the security option. Still getting same error and roborock failed to connect
Router model - Netgear Router R6900V2 Night hawk
I just ordered a new TP-link mesh system. Getting pressure at home as my roborock is not cleaning/working for couple of weeks.
- michaelkenwardApr 08, 2022Guru - Experienced User
