jpharper999
Sep 01, 2021Tutor
NETGEAR Router Remote Management BAD
I own a R8000P router. I have it specifically set up to NOT allow Remote Management If I type in the http://<external IP Address> from another physical location, it prompts me for credentials and th...
Sep 01, 2021Guru - Experienced User
what firmware version are you on?
jpharper999
Sep 01, 2021Tutor
| V1.4.1.68_1.3.28 |
No newer firmware available according to the Management Check functionality of router
- plemansSep 01, 2021Guru - Experienced User
could be a bug. I don't have that specific router to test it on.
DarrenM or ChristineT any chance you guys do?
- michaelkenwardSep 02, 2021Guru - Experienced User
Not always a reliable guide.
It can miss things like this:
R8000P Firmware Version 1.4.1.82 - Hot Fix | Answer | NETGEAR Support
Always better to visit the support pages for your device.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.- jpharper999Sep 02, 2021Tutor
Will try that... Appreciate ya pointing me to the Hot Fix.
Reading the notes... I do not think this update will fix the issue... Maybe I will get lucky... From a cyber security standpoint... The web login page should not even be accessible at all from outside unless Remote Management is specifically enabled. That in and of itself opens the router up to an attack which eventually could succeed.
Updated with Hotfix...
admin page still be advertised to outside my network...
Updated my password to a very large random sequence... oh well....
such is life
