jpharper999
Sep 01, 2021Tutor
NETGEAR Router Remote Management BAD
I own a R8000P router. I have it specifically set up to NOT allow Remote Management If I type in the http://<external IP Address> from another physical location, it prompts me for credentials and th...
jpharper999
Sep 01, 2021Tutor
| V1.4.1.68_1.3.28 |
No newer firmware available according to the Management Check functionality of router
Sep 01, 2021Guru - Experienced User
could be a bug. I don't have that specific router to test it on.
DarrenM or ChristineT any chance you guys do?
