MikeT62
May 13, 2020Tutor
Netgear security is compromised on NETGEAR-5G-2
R7900P — Nighthawk X6S AC3000 Tri Band WiFi Router My router is password secured w/WPA2-PSK [AES], and I have Smart connect enabled. The problem is NETGEAR-5G-2 is advertised and connects without...
- May 13, 2020
have you tried a simple factory reset and re-install?
Or even re-installing the firmware?
