MikeT62
May 13, 2020Tutor
Netgear security is compromised on NETGEAR-5G-2
R7900P — Nighthawk X6S AC3000 Tri Band WiFi Router My router is password secured w/WPA2-PSK [AES], and I have Smart connect enabled. The problem is NETGEAR-5G-2 is advertised and connects without...
- May 13, 2020
have you tried a simple factory reset and re-install?
Or even re-installing the firmware?
MikeT62
May 13, 2020Tutor
Firmware Version: V1.4.1.50_1.3.10
May 13, 2020Guru - Experienced User
- MikeT62May 13, 2020Tutor
Not yet. But I will as soon as kids finish school work. I'll reply back with results after complete. Thanks!
Reinstalling the firmware did not fix the problem. However, resetting the modem by pressing and holding the reset button in the back of the router with a paperclip for 15seconds corrected the problem. I guess when in doubt, reset first! :-)
Thanks for the help!
