Al12345
Feb 01, 2017Aspirant
Netgear support contact number for Ireland not in service
Guys
Whats the story with the support number given out for Ireland not being in service?
Ive seen posts six months old with people complaining about the same issue.No response from email for supp...
- Feb 04, 2017I did get a number. A U.K number.
The Irish number is no in service. Why not give the UK number on the website?
That said the support I received once I did make contact was second to none.
ConnDublin
Feb 07, 2017Aspirant
I have completed the online forms seeking to replace a faulty GS116 switch and got to the point where I am asked to call the non-working number (0818-904000) with my case number (28033920). There is no visible means on the screen to convert this into an email enquiry. I can neither call nor email nor establish contact by any means other than this forum, it would appear. All help appreciated. ConnDublin
ElaineM
Feb 13, 2017NETGEAR Employee Retired
ConnDublin Kindly PM me your contact information. The case number does not exist, can you provide me as well the serial number of the switch?
- ConnDublinFeb 13, 2017Aspirant
Dear Elaine,
Happy to send all details to you - I am not sure how to "PM my contact information" to you? My email address was provided at the time of registration for the forum, if that is of any use. If you tell me what steps I need to take, I will follow them. In case of a typo, the case numbers I noted (2 switches) were 28033920 and 28034008.
Kind regards,
ConnDublin- ElaineMFeb 14, 2017NETGEAR Employee Retired
ConnDublin I initiated a private message with you. Kindly check your inbox.
