ChesticlesMcgee
Apr 10, 2021Aspirant
Netgear support R7800
My router will no longer keep its settings and goes back to the default settings when power cycled. It is also randomly rebooting now. It's only 3 months past the warranty date. The last router I own...
- Apr 11, 2021
Just wanted to follow up, in case anyone else is searching for a solution, beyond warranty....
I tried all the older firmware versions from Netgear back to .68, and they all failed for me. From my research, .68 seemed to be what everyone said was the most stable version with the least bugs. They would never save the settings, and it still continued to randomly reboot.
I found in my search that DD-WRT was compatible with this model. I didn't have anything to lose, so I tried installing the DD-WRT firmware. I had some weird initial issue with it freezing the web pages with the latest version, 44719, using the DD-WRT Factory image. I reloaded the previous version of DD-WRT, 40559, using DD-WRT Webupgrade. Everything worked. When I rebooted the router, it no longer lost the settings. I then tried the upgrade back to 44719 using DD-WRT Webupgrade, and everything is working great. 24 hours and so far so good.
Time will tell if this works. I'll try to remember to check back in a week and leave an update. It looks promising so far, and if this works, saved me a lot of money to replace it. I hope this might be useful to others that run into the same issue.
Many thanks to the folks that tried to assist me. I really appreciate it.
ChesticlesMcgee
Thank you for responding!
I downloaded the version I mentioned earlier from the Netgear site. Where are the older versions located?
Apr 10, 2021Guru - Experienced User
Nighthawk X4S R7800 | AC2600 Smart WiFi Router | NETGEAR Support
click downloads and then click "+view previous versions"
- ChesticlesMcgeeApr 10, 2021Aspirant
I guess I'm out of luck. I've tried every version all the way back to .68, and it will not save the settings. :smileysad:
- antinodeApr 10, 2021Guru
> default settings when power cycled. [...]Sounds to me like hardware. Test/swap the power adapter?
> [...] how do I find out if I can get it fixed? [...]
I've never seen a repair service for these gizmos; they don't cost
enough to justify any skilled labor.- ChesticlesMcgeeApr 11, 2021Aspirant
