ethonkent
Jul 28, 2023Follower
Netgear wifi 5 mesh vs wifi 6 router
I live in a mid-size condominium and proper now i have Netgear Nighthawk AC1900 which serves as my modem and router. It is been getting sluggish currently and would love to update it. Am no longer c...
microchip8
Jul 28, 2023Master
If you want seamless WiFi roaming, then you can't avoid the Orbi. For everything else, considering your speeds, the router+modem combo is fine.
michaelkenward
Jul 28, 2023Guru - Experienced User
I moved on from Orbi to the MK Mesh routers recently, wipes the floor with Orbi.
- FURRYe38Jul 28, 2023Guru - Experienced User
My 8 and 9 series Orbi work far better than the MKs IMO.
- michaelkenwardJul 29, 2023Guru - Experienced User
I jumped several generations, from oldest Orbi to newest MK.
If nothing else, the design of the Orbi is horrible in comparison.
- FURRYe38Jul 29, 2023Guru - Experienced User
Hard to claim that since you haven't seen newer generation Orbi. HW is solid. Far better than the MK HW.
