wahbucket
Dec 09, 2020Follower
Netgear Wifi Range Extender Keeps Disconnecting from Router and Powering Down
My wifi extender is being extremely malfunctional. I have attempted to write this out several times only for my extender to randomly power down completely while plugged into my outlet. My internet ga...
Dec 09, 2020Guru - Experienced User
Maybe something was corrupted in the firmware when the "internet gave out".
Try manually reinstalling the firmware to it, then factory reset, and install using the installation assistant (not wps)
https://www.netgear.com/support/product/ex3700
might want to post in the extender section next time.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
