joblack4949
Jan 16, 2023Aspirant
Netgear wifirouter R7900P is not blocking
Very concerned. I've added googleusercontenet.net in the block site, fire wireshark and it still goes there. Doesn't show as blocked. What gives?
Jan 16, 2023Guru - Experienced User
is it an HTTPS site?
If so, blocking won't work as its encrypted
- joblack4949Jan 16, 2023Aspirant
Not sure what you mean. I am not asking to block content, i am looking to block destinations. In the security options, clearly states "blocking sites containing key words or domain". that is url=domain. I don't care about encrypted communication and fully aware it is ssl encrypted. But i do care if googleusercontent is stealing information and for that reason alone, i should be able to block destinations.
- FURRYe38Jan 16, 2023Guru - Experienced User
I believe what is meant is that the blocking feature of the router don't block any connections to remote sites that use HTTPS as there entry into there pages. The router can only block HTTP sites.
I belive of you want more blocking of HTTPS sites, you'll need to look into DNS services like OpenDNS that I believe can support blocking of connections to sites that use HTTPS.
I bought this netgear because a similar document found. Still not sure what you mean. According to this document, youtube is an https site and it is clearly listed there with no mentioning it cannot block anything other then http sites.
- michaelkenwardJan 16, 2023Guru - Experienced User
For better informed feedback could be it might help if joblack4949 explained why they want to block these sites.
There may be other solutions.
Aha, just spotted the later message.
I don't understand it.
Seems to confuse incoming and outgoing.
You seem to be missing some network fundamentals. I don't care what the ssh encrypts. The packet sent across the wire, amongst other things, it contains the destination. That is at the network layer (layer3). And that is what a router functions at. It is a layer 3 device. That said, no one cares what is being transmitted and again, i am fully aware data is encrypted, but i would expected as a quite expensive router it is capable of blocking destinations. In fact this is taking from their site:
