joblack4949
Jan 16, 2023Aspirant
Netgear wifirouter R7900P is not blocking
Very concerned. I've added googleusercontenet.net in the block site, fire wireshark and it still goes there. Doesn't show as blocked. What gives?
Jan 16, 2023Guru - Experienced User
is it an HTTPS site?
If so, blocking won't work as its encrypted
michaelkenward
For better informed feedback could be it might help if joblack4949 explained why they want to block these sites.
There may be other solutions.
Aha, just spotted the later message.
I don't understand it.
Seems to confuse incoming and outgoing.
- joblack4949Jan 16, 2023Aspirant
You seem to be missing some network fundamentals. I don't care what the ssh encrypts. The packet sent across the wire, amongst other things, it contains the destination. That is at the network layer (layer3). And that is what a router functions at. It is a layer 3 device. That said, no one cares what is being transmitted and again, i am fully aware data is encrypted, but i would expected as a quite expensive router it is capable of blocking destinations. In fact this is taking from their site:
