Hoglets's avatar
Hoglets
Follower
Apr 28, 2021
Netgear X10 R9000 not broadcasting WIFi
Hi All
I have a Nighthawk X10 R9000 router and i am attempting to connect 2 No. Panasonic wifi enabled cameras (Lumix TZ95 and Lumix G7) to the router. However, both cameras can not detect the SSID of the router although other devives (ipads etc) are able to do so. I have checked that the  SSID Broadcast option is correctly set to 'on' through the router settings menu.
Does anybody have any ideas of additional settings that I may need to make/try so the SSIDs are visible to both cameras?
Thank you in anticipation
Hoglets
1 Reply
  • plemans's avatar
    I'd check with the camera manufacturer. If everything else can see the network, it seems to indicate an issue with those devices.
    Maybe they require specific channels used for wireless or need their own hub.
