johngrady
Sep 09, 2021Aspirant
netgear X4 , starlink
says not compatible , no WPS on starlink , many other devices just hook up with wifi password . Why not this extender Starlink extender needed !!!!! Said nothing about not compatible till after you...
Sep 09, 2021Guru - Experienced User
X4 doesn't mean much here in the forums.
What NG product are you referring too? Router, extender?
Contact the mfr of starlink for help and informatino regarding there product.
johngrady
extender nighthawk x4 ac2200 ex7300v2,
problem is not starlink works fine with no extender . starlink router has no wps buttons .
message came “ your router ( starlink standard ) is not compatible with starlink .
you find that out after buying it !
- michaelkenwardSep 10, 2021Guru - Experienced User
johngrady wrote:
starlink router has no wps buttons .What is the model of this Starlink device?
Too many people get the impression that Netgear routers lack WPS. In reality, they just haven't found it, partly because this feature isn't always easy to find.
Perhaps Starlink is equally obscure.
