johngrady
Sep 09, 2021Aspirant
netgear X4 , starlink
says not compatible , no WPS on starlink , many other devices just hook up with wifi password . Why not this extender Starlink extender needed !!!!! Said nothing about not compatible till after you...
Sep 09, 2021Guru - Experienced User
did you try installing it using the installation assistant?
the EX7300 is an extender only. not a router.
so you need to make sure your starlink router is running (and usable), then set it up using the installation assistant.
- microchip8Sep 09, 2021Master
There is no guarantee the extender will work with Starlink. It's not even certified for it. Next time do a bit of research if you want compatible Starlink devices.
